PanelView Plus 700
Waseem_Akhtar
Jan 2017
Bangalore
Hello everyone...
I'm facing one problem on recently purchase the PanelView Plus 700(Cat.Log 2711P-T7C4A8, SER A). FactoryTalk View ME Ver 9.00, *.mer ver 9.0(I tried in V5.1, V7.0, V8.0, and V9.0) RSLinx Ver 3.81.
Error "The Destination selected is not a valid device. Please select the Valid destination and try again"
I face this problem if we use ME transfer Utility for PanelView 800 Device. That's acceptable.
Please help me...
Thanks in advance
Have you tired to transfer the .MER with a CF or USB?
Are you sure that the new PV is 9.0 and not 10.0?
If it is try deleting the driver in Linx enterprise and build a new one.
If you have Tech Connect support search 24344 and 276779
Yesterday I downloaded with USB only...
If your asking for PanelView Versions then its showing 10.
I think the version may be wrong there is 2 ways to fund the version ,
1) on boot up the hmi shows the version as app (9.0app) would be verion 9
2 go into config screen -teminal settings- system info-about factorytalk
Then create a runtime to that version ?
HMI Version is 10..
I transfer the file with USB and its working good..
I think version is not an issue because we can make a .mer file with lower version.. Of it's creating a problem then after download error have to incompatible version...
Some HMI's have v8 and lesstgen that version .Mer file runs fine..
My Panelview plus 700 HMI stopped working and I replaced it with a new one. Moved the sd card from the previously installed panel to this one and...
998
Good day all! I need to make some modifications to a Panelview program. I uploaded it from the unit. Tried to use the Application mgr. to...
1,092
Hi All. I am working on my home automation system again and i am looking at setting up a panelview. Currently running an AB Compactlogix...
843
Hi. I'm working on a plant that has a panelview plus 700. Problem is that from time to time, the alarm list shows an old false alarm instead of...
2,771
