panelview program
djc950
Apr 2005
tx
hi there, i new on programming the panelview, maybe somebody can help me this. our company had 600 panelview ,and i try to upload the program,but when i open the program it has warning not panelview32 or coorupt file .( *.pva)do i have to convert this files? thank for help
A *.pva file is a Panelview file using Panel builder software,
I do not recall a Panelview 600, and wonder if you are trying to upload a Panelview plus program, which would have been made using RSView studio
Most panelviews have a black front, while most panelview plus have a gray front
If it is a panelview plus, you are not able to do an upload and alter the program, but you must have a copy of the origional *.med file, or its *.api archived file
Panelview 600
Whats the Panel view part number? 2711******* ?
Product: 2711-T6C5L1
Description: PanelView 600 Color, RS-232 (DH-485) Communication Port
What version of PanelBuilder32 are you using? Frequently you will get errors if, for example, you try to open a *.pva created in version 3.82 with panelbuilder32 version 3.80.
The panelview program was probably developed in a newer version (3.80). You could post your PV program and let others here try to open it with newer versions. That will tell you if it is a version problem.
Hi all, Im having trouble transferring a program from one panelview 550 to an new one. I can insert a flash card into the old panelview and upload...
20
381
Hi, its been awhile, hope y'all are well. I do not have RSView Studio or whatever the HMI specific programs are for working with .mer files I have...
296
Got a problem on an install this weekend I'm hoping someone can help out on. I'm upgrading an old system with a SLC5/04 and Panelview 600...
1,157
Hi all, I have a 2711R-T7T running an application without a shutdown button in the current program. I've looked at all the manuals and can not...
1,284
I've got an old PanelView 1000 here where I've been asked to recover the program because nobody has a copy of it. I was led to believe that just...
2,134
