Peak Canbus Usb
userxyz
May 2002
any
2,768
How do u need to connect to a CAN-BUS ?
It's for using the 'Global Drive Control' tool.
I have the USB to CAN converter, but, what to connect, Can-Hi and Can-Lo or ...
tnx for help
Combo,
simply connect CAN-L to CAN-L, CAN-H to CAN-H and GND to GND as is shown in this picture. Also don't forget to put a termnation resistor of 120Ohm at both ends of the CAN-bus.
Kind regards,
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
147
Hi everyone, I'm working on a project that involves using a Keyence LR-X100 sensor in Studio 5000 V35 ladder logic to determine the object's...
689
I have an analog flow signal that fluctuates with many peaks and valleys. Occasionally due to valve changes a peak value (or several) will be way...
1,244
I have an application where I need to know the peak pressure of a machine and time at peak pressure. I am wondering does anyone know of an...
1,576
I've been doing Modbus for 20 odd years but almost never do I have to use a slave simulator. Until today. I used Peak HMI's freeware RTU slave...
1,968
