Playing Sound
srinathair
May 2016
I have two Alarm groups for Two Areas which contain both High & High High Alarms. whenever there is an New Alarm a alert sound is being played (.WAV file) using PlaySound().
Requirement: I need to Play a separate Sound for High Alarms when there is a High Alarm Alone from any of the Alarm Groups.
Similarly I need to Play a different sound to High High Alarms when there is a HH alarm from of the Groups
Kindly Help me out with Intouch Script to achieve this
High High Alarm has the Highest Priority
AB has horns with different frequency outputs(I guess other brands do the same)you can use a horn with frequency1 for high and other horn with frequency2 for high high alarm.
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
381
Using FTview ME to create an HMI screen. Simplest task is giving me trouble. How do I create an HMI tag that will allow the name of the current...
150
Hello Folks, plc : micrologix 1500 The analog output from the loadcell is given to the plc. Using the SCP function I have scaled it into an...
779
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
619
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,101
