PLC-2 Help
ramil
Guest
R
Dear All,
I am converting PLC-2 to PLC-5 and i am stuck up.
I found that PLC-2 Timer status dbit are little bit different.\\
Finally I mapped that Bit 17 in PLC2 equals Timer Enable in PLC5
Bit 15 in PLC2 equals Timer Done bit
Bit 16 is used as flasher.
But i want to know what bit 14 in PLC2 timer represent.
I searched manuals and could not find it.
My question is that Timer timing bit or something else.
I could only find bit 14 equal to Overflow and that too in counter and math instructions.
Hope some PLC2 gurus might help me about bit 14.
PLC is mini PLC2/16 .
thanks
PLC2, a long time back!
That is because bit 14 is only used in those instructions. The timer words have a bit 14 but it is not used for anything. If it were, the manual would have defined it for you.
The PLC2/16 manual says:
14 Overflow/underflow bit. It is set when the AC value of the CTU instruction exceeds 999 or when the AC value of the CTD
instruction falls below 000.
Hope this helps you solve your conversion problems.
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
86
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
62
I have a network with 4 PLCs PLC1 is controllogix and PLCs 2-4 are compactlogix and they all need to communicate. The current way I have this...
271
So to start off: I have no experience with PLC's, but I'm good at figuring stuff out, but I need some help to know if my PLC is just dead in the...
121
Hi guys, I have no experience when working with AllenBradley PLC, but I hope someone could clarify the result of multiplication shown in the...
2,217
