PLC-200 Baud rate Change
shriganesh
Nov 2010
Pune
Hello,
I am using CPU226 I have downloaded Logic with 9.6Kbps Baud rate.It running ok.To increase Transmission speed I have to use baud rate of 19.2kbps.
I used MPI cable instead of PPI for downloading and change the settings as shown in attachment.When I tried to download it in CPU226 it gave me an error that Port could not be open or it has been used by another user.
Pls tell me solution if anyone have it.Pls see an attachment for referance.
Regards,
Hi Shriganesh,
Did you change the baud rate of your communication driver as well? You should leave that at 9.6K whilst you do the initial download then change it to 19.2K when the new port settings have been transferred. You could try ticking the box for 'check all baud rates'...
Hope this helps.
Rob
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
58
34
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
99
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
242
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,962
