PLC communications
PLCgirl
Feb 2003
PA
23
I was wondering what RS linx software is needed for the AB 1200s. We have RS logix 500 version 6 which is capatible unfortunatly we are unable to trasmit data from the computer program to the PLC. We are using RS linx 1.7. Is this an outdated RS linx software or are we screwing up on something else?
On the RSLogix CD-ROM there might be an installation for RSLinx Lite. It doesn't always install automaticly. I don't have Version 6 so I don't know if it was included. Try to find it on your CD-ROM and install the latest version, (should be ver 2.30 or higher, I think).
If it isn't on the CD-ROM, I think you can go to the rockwell website to download it.RSLinx Lite is free but higher grades require buying a license.
Sid
The latest version is 2.40.00 and if you register with AB you can download RSLinx Lite for free. To use with OPC/DDE I believe you would have to have RSLinx Professional.
Hello, I'm trying to delve a little into rs-485 communications for a couple projects of mine. Until now I've been using a delta vfd and a delta...
129
Hi guys, This my first time posting hope I get help in my issue.. I have Allen bradley control logix safety PLC (1756-L61S) connected with...
2,315
Hi All, I have 2 ControlLogix 5570's that are supposed to each send each other some info over Produce/Consume tags. For convenience, I'll call...
2,726
Hi, To give some context of the situation and why I'm posting. I started a PLC module as part of a general engineering course last year and the...
2,040
Hi everyone I have a Harvest VFD VB5N 0.75Kw it have an ethernet port and RS485 is it possible to control it with s7-1200 plc via the ethernet...
1,299
