plc for prover meter
Prover meters that I am familiar with are used in the petroleum custody transfer field. They are usually a large horizontal cylinder with a piston. The fluid is forced into the cylinder. The movement of the piston trips limit switches at either end. The volume in between the limit switches is a known volume. The temperature of the fluid is monitored. Based upon temperature and volume, a mass quantity is calculated. The same volume flows through the meter under test. The meter under test is usually a turbine meter or propeller meter with a pulse output. The meter is calibrated in pulses per gallon. This number is commonly called a k-factor. Based upon the results of the prover, the k-factor is recalculated to match the prover value. The test is run three times for repeatability.
As for PLCs, I have never seen them used but they could be. You would need a high speed counter input to read the output of the meter under test. Most meters are already connected to some kind of transmitter which provides excitation to the coil around the element and a display of pulses and GPM and standard GPM.
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
57
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
55
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
45
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
86
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
82
