Please Gurus Help
Mark Buskell
Sep 2003
Florida
892
I been commissioned to do this project. I have a 480v in a nearby panel and I need to get 24vdc from it to power some 24v input modules. I am not an idiot and know I cannot hook to it directly. I read up on Omen's law and voltage drops. Can I just take a couple of strands off 2 of the legs and get my 24. My math worked out fine according to this Omen's law.
What is extremely sad, is that lately, this is exactly the kind of question I see posted here. It scares the **** out of me to think of some of these people playing with electricity.
Mark,
First of all, its Ohm's Law, not Omen's Law. Secondly, you can't just take a piece of your 480VAC & get 24VDC. You need a 24VDC power supply. Most power supplies operate from 120VAC. Do you have a 120VAC outlet available?
If you try to connect to the 480VAC directly, you may get badly hurt!
NO. NO. NO. Every strand of a wire that is at 480V is at 480V, voltage cannot be divided or reduced this way. Each strand carries a certain amount of current, but all have the same potential(voltage). Someone trying this is sure to blow up something, if not kill themselves.
What a joke. I know I have asked some newby questions before but WOW! Somebody actually lets this guy work in thier facility?
I would never look down on somebody learning and looking for advice but it is clear this person is not a journeyperson and should not be working alone at anything.
First problem... someone hired you
I have a 480v in a nearby panel and I need to get 24vdc from it to power some 24v input modules..
Second problem, your inputs are 24v DC... you will need to install a rectifier also, you can not use AC inputs
hmmmm lets leave this one alone for now
I dont believe in any Omens... you may need to see a preacher and have an exorcist
I am using FTView SE 5.10 I am trying to figure out the best way to do the following. I have a graphics display that contains 10 String Display...
2,488
please help me . I have to make this ladder diagram and I can’t figure it out :(
402
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
80
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
178
Hello, I am trying to get a Yokogawa Hart pressure Transmitter and a Rosemount Temp Transmitter to read on a 1769-IF4 module on an L33ERM...
396
