PowerFlex 523
Rato_Ribbon
Aug 2021
Texas
Hello,
I wanted to program the parameters for powerflex 523. I gave 480V to the powerflex but I didn't do grounding and turn on the power. But the powerflex doesn't turn on. I mean the screen didn't show anything. It didn't turn green. I checked the voltage using multimeter and I am getting 480 V in powerflex.
What could be the possible reason?
(It was working fine the previous day.)
Thank you all.
Hello,
Thank you all.
* The two pieces of the PF523 might not be properly engaged (Front-to-back)
* Your 480 might be wired to the OUTPUT terminals, not the INPUT terminals.
* Bad drive>
Thank you so much. The two pieces weren't connected together so it wasn't displaying anything.
It works fine now.
Thank you.
Hello everyone, I am trying to upload some parameters from a powerflex 523, and download them to a new powerflex 4. First problem is I’m not...
643
Hi, I am having issues with Studio 5000 v32.02 and connecting to a 523 PowerFlex drive via Ethernet. My network consists of a 5380 CompactLogix...
1,869
I get the F003 fault from time to time. Incoming voltages L1 400V L2 390V L3 410V. Any suggestions on solving this problem would be helpful.
2,815
Hello, I am looking to upgrade some controls and logic on one of our pieces of equipment in our manufacturing plant. I need to be able to force...
4,183
Hello, So I am trying to set the parameters of a pf523 with a Micro850 PLC all done over CCW. I've set it up before with RSLogix5000 where when...
2,464
