Powerflex 525 Control Module
jayare12
Dec 2010
oregon
20
So I have a simple question when changing a 525 control module am I able to use a control module from a 5.0 HP on a 2.0 HP? I have looked everywhere for any notice on whether or not it is allowed but no success. When I use the USB tool to load a configuration file I get an error but it still allows me to load it but the initial app screen still states it is the original HP rating.
Yes you can do it, all control modules are the same regardless of size or voltage. But the power modules are coded and the control module is told of the mismatch when you plug it in. So if you do, the control module faults, forcing you to fix the power rating being out of range. You should be able to clear the fault by simply going into the motor parameters and setting everything correctly. You might have to do that off line however, I can't remember and am not in front of my PC just now.
So our Powerflex 525's are set up to allow REMOTE operation from PLC through network. But if network is lost we want to be able to run in LOCAL...
575
Hello All, I am working with a powerflex 525 trying to get multiple speed references. I got it working on my bench and then I went out to the...
1,092
Hi, I'm looking to see if there is a solution for an application I'm attempting. I have a PF525 running a pump. It is primarily hard-wired...
1,546
Quick question for all. Looking at upgrading my plants VFD's to PF525 however all the current plant controls are 120VAC. Can the PF 525 be...
3,812
Hi All. I am trying to commission a Powerflex 525 Drive but currently only have access to +24VDC, I simply want to assign Ethernet/IP Address...
18
7,775
