Powerflex 525 reset encoder
janasamara
May 2017
Portugal
20
Hi, people I have a problem with the reset encoder routine.
I can not reset encoder positions(parameters 376 and 377).
I followed the manual and tried to do the automatic startup routine but it does not work.
First through a plc input I try to activate drive input 7. At input 8 of the inverter I have physically attached a wire to the sensor. I also have parameter t67 set to "35 Find Home" and parameter t68 set to "34 Home limit".
I do not know what I might be doing wrong.
Can someone help me by doing?
thanks
Can someone help me ?
thanks
Hi All, I am working on testing a project with a Powerflex 525, final project will be a 755, and I am trying to reset the Elapsed kWh meter over...
636
Fairly new to the drive so apologise for the layman terms. Textile machine uses PF525 VFDs to control motors. The speed of the drive is currently...
136
133
119
289
