Problem with PPI-network with S7-200
mulderm
Jun 2003
Netherlands
298
Hello,
I have a PPI-network with a laptop with Microwin software and a Siemens S7-222 plc and an operator
panel ESA VT150W.
Problem is when I will going online with the plc I get a message: MASTERS EXIST ON THE PROFIBUSNETWORK AND THE CURRENT DEVICES DOES NOT SUPPORT MASTERS.
TRY AGAIN AFTER SELECTING A MULTI-MASTER DEVICE.
So I can´t go online on the network.
When I will disconnected the operator panel then I can online with the plc.
But this is not the way.
Who can help me?
Greetings,
mulderm
Dear All, some how we lost the USB side of the cable of our PPI adapter and now we don't know the USB pin configuration inside the PCB part a 4...
5,527
Hello Guys, I'm trying to program S7 200 CPU 212 using USB/PPI mm ( 6ES7 901-3DB30 - 0XA0 ). Uploading the program from PLC is good but when I am...
2,020
We have Siemens S7-200 PLCs in different machine. To get access to their program, I have arranged a USB/PPI Multi Master communication cable but...
7,507
THE CONNECTION IS ESTABLISHING AND DISCONNECTING CONTINUOSLY AFTER THE COMMUNICATION B/W PC "Protool" & S7200 PLC "AT RUNTIME" THROUGH PPI CABLE...
6,503
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
455
