problem with the program omron
heliosaucedo
Mar 2011
van nuys
37
hy guys ,
3 days ago i copy the program and then download it to plc,
after this i conected each wire in the point correct,
but when i turn on the machine for test i have some problems.
1.in the first steap the head feeding is not activate (ouptut.10h02) why?
normally this machine work in the mode auto.i check the diagrams for see where is the problems? i have more problems but this is is the first. thankou for you hellp
if someone helps me find the problem ,
hey Helio,
Can you keep the same post going
People will answer them
AS i stated
HAVE you checked the I/O wiring and confirmed them BEFORE
Attempting to run your program.
I am just getting started with a Omron NJ and am trying to get a basic ladder to work. I am sure I am missing a step or something. When a input...
1,510
Dear Friends; We have OMRON CJ1M CPU23 with I/O cards at one of our machine. We have arranged a spare PLC and tried to download the program...
6,942
Dear All, I tried to take back up program from Omron PLC model: CQM1H-CPU11 by the connect Peripheral cable & port. After stated communication...
2,708
Hello all of you!!! I have problem with program for concrete plant(CQM1H CPU 51,ID212 x1,OC222 x2,OC224 x1,AD042 x2) and need help from you...
4,451
Hi dears I am facing problem during program upload on S7 200 (226 cpu)microwin 4 sp9 closes on 100% I try to upload data blocks, its ok, System...
2,460
