PROBLEMA WONDERWARE INTOUCH V23 Y DASABCIP
MiniRick01
Jan 2024
mexico
Hola chicos.
Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos periodos de tiempo el driver se va a error y no recupera conexion y tengo que desactivar y activar el driver y reiniciar la aplicacion para poder recuperar la conexion.
Alguien que le haya pasado este problema y como lo pudo solucionar.
English Translation
Hi guys.
I have a problem with the dasabcip 5 communication driver, and a controllogix v34 plc, I have already communicated but in certain periods of time the driver goes into error and does not recover connection and I have to deactivate and activate the driver and restart the application to be able to recover the connection.
Has anyone had this problem happen to them and how they could solve it.
Community Verified icon
Are you running with a development license? The system runs for a limited time without licenses.
Is the IO driver licensed? Are you using the ArchestrA License Manager and ArchestrA license file, or the wwsuite.lic license file?
I have a Powerflex 755 controlling a Baldor induction motor of 100hp 3550rpm 120hz, the machine where this is a Langston Saturn II corrugated...
2,019
I migrated to a WSP2023 application. Now when I open a HMI object (for example a valve or motor) the popup is first correctly show as defined ...
54
212
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
131
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
220
