Proface ST403 ethernet connection problems
a.camacho
Jan 2009
H.Matamoros
Hi!
I'm having trouble when connecting a Proface ST403 to a Siemens PLC via ethernet. On the PLC side I have a CPU314 with a CP343-1 Ethernet card hooked up to a hub. I'm not using WinCC.
To try and set up the connection I gave an IP address and port to the Proface Screen and also to the PLC. On the PLC side using NetPro I set up a new station with the IP address and the port of the Proface screen. Also I use AGSend and AGReceive to try and stablish the connection. The Proface Screen displays PLC COM, ERROR (02:FE:0E), I don't know if this is the correct way to do it, or if it can be done like this, but I couldn't find any documentation on how the set up the Siemens communication part.
Hope you can help.
Best Regards
Hi all, i have several Proface GT2400 terminals and i need to get the software and interface cables and i have several questions. I am assuming...
165
I have followed the videos & still having issues getting the email out. Does anyone have knowledge or has sent an email notification via gp pro ex?
196
Has anyone found a Proface HMI that is compatible with Schneider M172 PLC?
390
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
350
Does anyone know if is possible to read data out of a ProfaceHMI/PLC into a CompactLogix PLC? I have a bunch of OEM machines on our plant floor...
499
