Proface to Toyopuc question
dbroms
Nov 2015
Chester
First post but need some advice about using a Proface screen connected to 3 Toyopuc PC3J's. All plcs have FL net/ethernet cards and are connected to a hub. i have connected a laptop to the hub and can ping each plc via ethernet. Question i have is how do i setup the addressing to communicate with the Proface ? I only want to use the Proface as a status screen , no commands to be sent to the Plcs just want to monitor inputs and outputs etc
any help much appreciated
Daz
Garry
Many thanks for your reply , that's exactly what I'm looking for. Will print out in work tomorrow and give it a go. Will let you know how I get on. Once again many thanks
Daz.
still having a few problems setting up , one thing is confusing me though. proface show connecting all 3 plcs via FL net to a hub then ethernet from hub to screen. whats the difference between FL net and ethernet ?
Hi all, i have several Proface GT2400 terminals and i need to get the software and interface cables and i have several questions. I am assuming...
167
I have followed the videos & still having issues getting the email out. Does anyone have knowledge or has sent an email notification via gp pro ex?
200
Has anyone found a Proface HMI that is compatible with Schneider M172 PLC?
394
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
354
Does anyone know if is possible to read data out of a ProfaceHMI/PLC into a CompactLogix PLC? I have a bunch of OEM machines on our plant floor...
501
