Profibus DP Redundancy, S7-400
sherman4
Jun 2002
46
Hello,
This is a question for you Siemens S7-400 Gurus: Is it possible to have Profibus DP redundancy having only ONE S7-414-3 CPU?, this is, having two Profibus Master Modules (CPs) acting one as the backup unit of the other one?
Is this feasible with S7-300, in case it cannot be done with S7-400?
Thanks for your answers.
Ok here is the problem we have a Siemens DP PLC (Master) and RIO ( slave) at the end of a Fiber Cable that runs through a Slip ring via OLMs...
495
Hi I like to know how the cable redundancy work in profibus. In order to provide cable redundancy I like to use two bus network for each slave...
5,415
Dear Sir, Is it possible to have redundancy in Profibus PA & Foundation Field BUS or not if yes how. __________________
4,919
Is the of Cable redundancy ( i.e RS-485 Communiation cable) on PROFIBUS been implemented ? Does in achieve the purpose of HOT STANDBY in case of...
4,813
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
199
