Redundancy In Profibus Pa & Foundation Fieldbus
Hello Chau...,
If you should want redundancy with fieldbus foundation you need to build a double network. This means a double sensor, double cabling eso. I know that Delta-V support in this way redundancy and there software is capable of dooing this.
I can't speak for Profibus PA but I think it's the same story.
Rudi
Ok here is the problem we have a Siemens DP PLC (Master) and RIO ( slave) at the end of a Fiber Cable that runs through a Slip ring via OLMs...
495
Hi I like to know how the cable redundancy work in profibus. In order to provide cable redundancy I like to use two bus network for each slave...
5,416
Hello, This is a question for you Siemens S7-400 Gurus: Is it possible to have Profibus DP redundancy having only ONE S7-414-3 CPU?, this is...
2,406
Is the of Cable redundancy ( i.e RS-485 Communiation cable) on PROFIBUS been implemented ? Does in achieve the purpose of HOT STANDBY in case of...
4,813
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
105
