Profibus PA or Foundation Fieldbus?
amberman
Jun 2014
Brighton
104
Having always used 4-20mA analogue signals we now have a project where the customer wants us to use a fieldbus system but has left it up to us which system that will be. Looking at our instrumentation suppliers that effectively means Profibus PA or Foundation Fieldbus. I've looked into the headline advantages/disadvantages and none seem very relevant to us e.g. we don't use Profibus DP, we don't care about FF devices operating with no host.
Both systems seem to be supported by our first choice PLC system (CompactLogix) and others such as S7 and Mitsu Q. So before I get stuck into the details of how to wire and program these systems to find some clear ground between them (time I can't really afford...) I thought I'd see what your thoughts are.
As I say, we're not limited even to PA or FF but I had to start somewhere and these seem the most likely candidates.
Any advice appreciated e.g. one is easier to set up or works better with AB or needs less wiring etc. Thanks!
Dear Sir, Is it possible to have redundancy in Profibus PA & Foundation Field BUS or not if yes how. __________________
4,917
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
198
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
94
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
115
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
328
