Proworx32 help needed.
Sliver
Feb 2004
Kingston, Ontario
488
New to Proworx32.
I am trying to configure a new project.
It is for an old 984-680 in a 7 slot primary rack.
I do offline setup and it accepts the 984-680 controller selection.
I try to do traffic cop but it comes up with S908 (remote I/O)
and drop 1.
I try to do an online configuration and it communicates ok(modbus)
It reads the controller properly.
I try to do the traffic cop but I get the S908/drop 1
I don't have S908 just the primary rack.
Any ideas how to configure my traffic cop?
What am I missing?
thanks,
Brian.
Found it...in case any others have the same problem keep S908 even when using the local drop and doubleclick on the drop. It pulls up a hightlighted area that has a box "Drop Series". To the right is a blank blue box that you click to drop down a selection with only one option "800 series". select 800 series and away you go. Not quite intuitive but now I know.
thanks,
Brian.
We just transferred a ProWORX32 license to a new desktop. After which we transferred back ups of all the projects.PWX files to the new desktop...
387
I was taught to go to Combined > Make Change > go to Offline > will prompt to save > Save > Exit out of program > will prompt to save again >...
680
I'm trying to use proworx32 for the first time and can't seem to insert a vertical short between blocks. When using the [| Short] button from the...
1,051
It's been so long since I've been inside of Modicon. Hope you can refresh my memory. Is it required to declare specific 400,000 addresses as...
1,508
Dear Friends, I have Schneider PLC which is the world's first one Modicon i need software of Modicon PLC 984,it is known as...
968
