PSTN Communication
teh
Supporting Member
Nov 2002
140
Hi Folks,
How should i communication between PLC and SCADA system through PSTN
lease line? what is the Bandwidth of PSTN?
Beside it , i have 20 Video Camera for monitoring, can the video
monitoring system software simultaneously with SCADA system software?
Regards
PSTN is Public Switch Telephone Network...ie Plain old telephone. Bandwidth will be same as a dial up modem, 56K. If you have 2 leased lines it may be possible to use shotgun technology to double the speed.
You could run the software simultaneously but I wouldnt unless its a very powerful computer using 2 monitors.
pstn
SO, how can i exchange the data between 2 plc through pstn lease line?
What additional hardware/software i shall use?
regards
It depends on what type of leased lines your talking about. Is it dry copper or something like a 56k circuit or frame relay. How do you plan on compressing the video? Leased lines are not dial up lines, they are a dedicated always on service
if the modem what i use is sinaut st7 , in this case which CP module i should use for s7300 PLC? Do i need addisional software? and how is the configuration?
regards
teh
One or two of the regulars here have dealt with Siemens teleservice, search this site for the keyword "teleservice", have a look for the thread started by Tom Jenkins, that might help you out in what with what you need to set this up.
Paul
Hello,ive got a plc 5 reading data from an slc5/03 40 miles up the river. It is done using two us robotics modems and a pstn telephone line both...
2,759
Hi All, Is it difficult to set up an ABSLC50/4 to communicate with an ABMicro 1000/1200 via a modem and a PSTN? I have two outstations that are...
2,719
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
26
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
100
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
40
