Pulse input from flow meter
JIBIN
Nov 2013
INDIA
I have a rotary flow meter,which will give 5000 pulse/second.I just want to calculate the cumulative flow,,per day flow,flow per hour etc,of three chemicals through the flow meter in litre , Using real time clock in the PLC ,and display them in a HMI. How can it is possible........?
Hi Andypot,
I am using a fuji plc, it is having a high speed counter and i am using it, i just want to calculate the flow at different time and store it for future reference.
You have to know the K-factor of the meter. Raw pulses are useless without a reference point. Usually they are in "so many pulses per gallon, BBL, etc".
The K-factor is usually on the meter, or you may have to contact the factory for a default value.
Its a TCS 700-20 rotary flow meter which will give 100 pulses per rotation and i am using a motor with 3000 rpm,so totally 5000 pulse/second.Per rotation 3.8 litre flows.I just want to know how to calculate flow in litre for a certain amount of pulses.
Hello all, I am working with a variety of discrete pulse flow meters, Siemens, Flomec, and Seametrics. I am attempting to read flow via discrete...
17
4,774
Hello everyone, i know there are some posts about this topic but none convinced me. I have an input pulse that comes for every m3 of water that...
5,465
Hi everyone this is my first post here. I have been reading a lot of the posts here regarding totalizing using pulses, however not exactly what I...
2,878
Just finished an upgrade from a SLC500 to CLX where they had a 1746-HSCE and we're now using a 1756-HSC. Two wire pulse signal from the...
1,305
Hello, We have the following DI card that can accept 1,2 and 3 wire DI's ( 6DL1131-6BH00-0PH1). We plan on installing this card for use with a...
1,514
