PV 1400 Terminal block transfer problem
RasPLC01
Sep 2011
AUS
56
I have a Allen bradly pv1400.I have been trying
ke to add 2 multistage indicators to the program.
When i did add the indications and try to downlaod, im getting a message of
"tag does not have valid address in the terminal assigned dicsrete rack or block transfer channel"
can anyone help me?
Thanks in advance
while you have added the indicators to the screen, you have not defined the tags - adresses to point to.
go into the indicators section and edit the settings
then do a verify all and download.
hope this helps,
james
hello friends i want to send some specific ascii character from PLC to my PC hyperterminal can any body help me in achieving this ?? i am very...
1,925
Dear members please give me a solution for following error in AB panel View 1400 which is communicating with SLC 5/03 I have been trying to...
28
6,361
We are unable to access the config screen, because there is no config button on the panelview screen. It appears that the other option of...
12,399
83
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
79
