Pv+ 600, 1761-eni, Ml1500
RBergmann
Jun 2002
California
258
I'm nearly through with configuring all the communications, but can't seem to get the short-cut in RSLinx Enterprise to recognize the ML1500.
Here's my setup:
RSLogix 500 V6.00.00
RSView Studio V4.00.00
PanelView Plus 600
1761-NET-ENI plugged into a MicroLogix 1500 LSP Series C
I can communicate to both the PV+ and ML1500 (w/1761-NET-ENI) with my programming software, but the PV+ apparently cannot 'see' the ML1500, but does 'see' the 1761-NET-ENI.
In searching the site, I was stoked to see a message as recent as June with the same setup, but apparently the goal was different.
Uh, it may be obvious, but the PV+ and ML1500 (1761-) are connected with Ethernet through the network.
Thanks,
... rab
I assume you have setup the "Local" and "Target" enterprise paths to the processor (usually the same path, so set-up the "local" path first, then click on "copy" to set the "target" path). I assume you have also successfully "test-run" the application on the "local" path - the programming machine.
Make sure when downloading to check the option to "Overwrite the PV+ communications set-up", at least for the first time downloading, so that the PV+ gets the "target" path to the processor.
Thanks for the response. Here's what is happening:
The paths that show in the RSLinx Enterprise Communications Setup window are the 1761-ENI and the PanelView Plus 600. Both with the IP addresses that I assigned. I deleted the 1761-ENI and then added the ML1500 LSP device and configured it with the IP address that I wanted. Seemed to work briefly but then changed back to the 1761-ENI device. Would never stick.
Then I came up with the idea of changing the IP address (to an unassigned address) of the 1761-ENI (only within RSLinx Enterprise Communications Setup) and then adding the ML1500 LSP. Seemed to work for the most part. The ML1500 and the PV+ appear to be communicating. However ... during one download (not all) the path of the new device change to the 1761-ENI.
Question: Whene do I find the option to "Overwrite the PV+ communications set-up"?
Transfer Utility
I will like to make a cable to connect a Control Logix 1761 with a Panel View 600 I have two DB9 - DB25 cables which I will sicrifice to make the...
8,013
Hello, I have a set of three tanks with their own trio of Hardy 6600 series load cells. Two of them have no issues with where they are at and...
169
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
117
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
121
I am trying to go to a 504 CPU. and on my hmi I am getting a 9028 error. can someone explain what they mean by change reference?
239
