PV 600 and L32E Daylight Savings Time Change
agrosse
Aug 2011
Grand Haven
24
I am using a PanelView 600 and an L32E Processor. Recently the time has changed due to Daylight Savings Time. My PanelView is now an hour ahead. How would i go about getting this time to sync up with the new time? And also so it does this automatically at the next time change?
My appologies but its a PV+ 700. There are two CAT numbers on the PV, one says Assembled CAT#: 2711P-T7C4D6, and the other says Logic CAT#: 2711P-RP6.
Thanks, I am not familiar with Panelview Plus so no help here. I am sure those that are will be here shortly to help out.
Got to the Configuration screen and on it you should see a terminal setting button and from there you should be able to navigate to time and select the Day Light Saving enable/disabled.
To get to the Config screen reboot the PV+ and while rebooting look in the lower left hand corner for a white box...Press it when it displays and that will take you to the COnfig screen.
Note the little white box may not appear on some of the older units but I am too lazy to look right now.
HTH
I'm not sure about the automatic DST change, but I do know that you can easily change the time and date on PV+'s by going to terminal settings on the configuration screen.
Cheers,
Dustin
I'm working on a new project. Trying to get a new RSViewME app to see my CompactLogix 1769-L32E. I'm alot-rusty with RSViewME. Problem is that...
7,791
Hello, I have a set of three tanks with their own trio of Hardy 6600 series load cells. Two of them have no issues with where they are at and...
149
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
109
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
119
I am trying to go to a 504 CPU. and on my hmi I am getting a 9028 error. can someone explain what they mean by change reference?
225
