PV to PVPlus conversion
Aug 2014
Earth
32
Unsupported Charaters, Tag Names and Addresses:
PanelBuilder32 software supports semicolons (;) in tag addresses; FactoryTalk
View ME software does not. Before importing your application into FactoryTalk
View ME software, change the semicolons (;) to colons :)) in the PanelBuilder32
tag editor.
PanelBuilder32 software supports dashes (-) in tag names, FactoryTalk View ME
software does not. Before importing your application to FactoryTalk View ME
software, search the PanelBuilder32 tag editor for tag names with dashes and
duplicate the tags. Rename the tags to eliminate the dash, or replace the dash with
an underscore (_). Use the tag search function to find graphic objects using the​
original tag names. Edit the objects to update the tag names.
My question is, will I need to change the tags in the PLC as well?
None of the A-B controllers allow dashes or semicolons in the address syntax; PanelBuilder32 was just more flexible to allow for typos.
You won't have to change the PLC address syntax in RSLogix.
I've been doing a lot of PV conversions lately and I'm fairly efficient at them these days, but on the last one I did for a customer, I didn't...
1,622
Hello, I want to make touchscreen push buttons invisible based on certain conditions. When these conditions are true, these buttons will become...
998
So I've got an issue I have yet to figure out. I have a PVPlus standard HMI runtime v12. I've gone into the system and set the date and time and...
4,867
Hello all. Sure hope someone can help with this. I have a system down because it is dependent upon its PV1000 and operator inputs to run it. I had...
1,607
I'm looking to use a second monitor as a data display for a customer. I know the FTVP is available but would like to actually duplicate the...
2,155
