pvp+ 1000 compact
ttis
Jul 2020
pakistan
Hi ALL !
i have a .mer file of panel view plus 1000 (2711P) *screen resolution PVPlus700/1000. But i have panel view plus 1000 compact HMI (2711PC). the problem is that i have restored the .mer file and when i try to convert the project on panel view plus compact 1000 (2711PC) it shows this error " unsupported driver ... " *picture attached but when i delete the backplane drivers which are *pictures attached and converted the project file to PVP compact 1000 it is converted normally but hmi is not communicating with the plc -as mentioned i have deleted some drivers does it impact the communication protocol - what is backplne drivers -
software version factory talk view 10.0
what should i do to counter this issue
Need help
iirc the backplane drivers are used in Design, delete them from the Runtime Tab. See http://www.plctalk.net/qanda/showthread.php?t=109187
Then make sure you have set up the Ethernet driver to match your physical configuration -- the HMI screen you show has a SLC 5/05 and a Compactlogix 1768, your development screen has a 1769 and none of the IP addresses match.
Hello, I made a small change to my FTV ME file (added an ack-all button) and re-downloaded to my PVP. Since then, when the application starts up...
1,031
Hi, im looking to migrate a 2711-K10C10 to a 2711P-T12W21 Panelview Plus 7 Standard. I migrate the PV1000 application .pba file in FactoryTalk...
1,979
Hi all Long time since ive asked for help hear but hear we go. I have been asked to make some new alarms on a lines panel view plus 1000 from a...
1,500
I'm working on learning how configure Factorytalk applications to communicate through serial to older controllers but I've only got a beat up old...
2,721
We have an HMI that when an application is loaded the HMI it asks if you want to change the terminal configuration settings to match the...
3,165
