PVPlus 1000 reboots when PLC goes to run mode
phuz
Jun 2008
Mohnton, PA
1,044
Looks like I'm experiencing a lot of "firsts" this week. Here's another:
Loaded a program into a PVPlus 1000 (F/W 8) and PLC program into a L36ERM (F/W 30). PVPlus boots up, shows values, etc., but when going into RUN mode, the PVPlus reboots and gets stuck in a boot loop.
Have you bought any small adorable pets from a curio shop in Chinatown lately ? Maybe ones with very specific feeding instructions ?
Be sure that the PanelView isn't in the I/O tree of the controller project. That can cause some weird problems, though I've never heard of this specific problem.
More importantly, check the supply voltage and be sure the something you have connected to outputs that get energized at startup is not dropping the +24V too low and causing a reboot on brownout.
LOL, not in controller tree.
But we'll check voltage.
Update:
Installed F/W 9 in the PV and it's staying alive now. I don't like it.
Hello all. Sure hope someone can help with this. I have a system down because it is dependent upon its PV1000 and operator inputs to run it. I had...
1,602
Hello everyone, I'm working on FT ME v.7 (My setting are below) and I didn't insert any storage cards. Max. data points : 1,000,000 Path : System...
1,263
Hello everyone, I'm working on FT ME v.7 (My setting are below) and I didn't insert any storage cards. Max. data points : 1,000,000 Path ...
1,116
Hi. We have a PvPlus1000 that is showing the following error code: (LegacyDP0x002047D0) Timed out reading from block 0x00222E88 Can't seem to...
1,662
Hello Friends, I have PV+ 1000 HMI programmed by someone. I donot have .med/.apa/.mer files with me. I am trying to upload the .mer file from...
4,582
