Question by noob
choban1984
Mar 2011
croatia
Greetings,
pardon my english, my lack of understanding PLC's and so forth
I'm looking for directions for a problem that i have. I'm working for an electric company. Nowdays, we are trying to implement remote control of high voltage circuit breakers in some of our substations. The installed circuit breakers already have DC motors that enable the circuit breaker to open. All we need to do is to find a way to send the command signal to some sort of PLC (that's probably the only signal that needs to be send from the control center) via wireless Ethernet connection. Not to complicate much I would appreciate if you cold give me some pointers on where to start from without going into verity of PLC (if i'm thinking right this PLC should be simple enough because it only needs to send status to control center and receive one or two commands).
Tnx a bunch!
I work in a field where our plc and hmi are constantly being powered fully off and on daily before being sent out. I am new to the world of plc...
973
Please laugh… but can I take 24volts from an IO module and wire it straight into its own input card to simulate an input….?
1,285
Hello. I'm wanting to use a boolean value associated with turning an output on to control the visibility of an image. The visibility option in...
2,165
Hello, I did a programming using MOVE block. However, whenever i press input. The MOVE block does not read the value assigned to transfer. Instead...
2,653
Hi, I have tried everything but still having no luck. This will be a easy solution I just know it. Ok I want to be able to set off an output...
1,803
