BachPhi Member Join Date Dec 2007 Location Los Alamos Posts 640 Oct 11, 2019 #1 Just curious, if you can check to see what your top ten apps that use most of your RAM memory. Last edited: Oct 11, 2019
dmroeder Lifetime Supporting Member Join Date Apr 2006 Location Vancouver, WA Posts 3,606 Oct 11, 2019 #2 Samsies for me.
Aabeck Member Join Date Feb 2013 Location Detroit Posts 1,860 Oct 11, 2019 #3 Windows 10 Pro X64 The first Rockwell item is FT Activation Boost coming in at #34, using 6.4MB. And RSlinx and FTAM are running
BachPhi Member OP Join Date Dec 2007 Location Los Alamos Posts 640 Oct 12, 2019 #4 Did you click the Memory column to sort from High to low?
Aabeck Member Join Date Feb 2013 Location Detroit Posts 1,860 Oct 12, 2019 #5 Yes, sorted by memory, high to low. Today FTActivationBoost is running about 20th place in memory. As for CPU usage Rockwell Automation, Inc Component/ FTSysDiagSvcHost kept jumping up to 3rd or 4th place
