raOSGI Rockwell top ten memory eater
BachPhi
Dec 2007
Los Alamos
641
Just curious, if you can check to see what your top ten apps that use most of your RAM memory.
Windows 10 Pro X64
The first Rockwell item is FT Activation Boost coming in at #34, using 6.4MB. And RSlinx and FTAM are running
Yes, sorted by memory, high to low. Today FTActivationBoost is running about 20th place in memory.
As for CPU usage Rockwell Automation, Inc Component/ FTSysDiagSvcHost kept jumping up to 3rd or 4th place
Background for the question: A service man from a sub-supplier has made changes onsite to a Siemens PLC and HMI program. He has not made a backup...
294
Hello all, I am an Industrial Electrician, and deal with a little bit of everything including PLC troubleshooting and programming. When I started...
171
I am working on a large migration of the standard PID instruction to the PlantPAx P_PIDE. Has anyone done a migration like this before and have a...
175
Hi all. What is the purpose of that block (MVM) when used with a 2#1111_1111_1111_1111 mask in that situation? I'm really hoping there is...
180
Customer is adding an extension rack to an existing A22. They wired and powered it up, I configured the new cards in the PLC starting from slot 23...
158
