Really this simple??
leitmotif
Nov 2004
Seattle Wa. USA
3,680
Got to calculating how much material I can put on a reel. Assume flat material whose width is same as reel ie not wire rope. Assume 1/2" thick such that one wrap is a change in diameter of one inch.
Here is what surprised me the change in circumferance per inch diameter change is 3.14 regardless of "starting diameter" ie circumferance change at 4 to 5 inch is same as that from 60 to 61.
Is it really this simple
circumberance change = Pi(D1 - D2)
or am I not thinking of something?
Dan Bentler
There is an old riddle that goes something like this:
Imagine the earth is perfect sphere with a 25,000 mi circumference and someone has put a steel band tightly around the equator. I have cut the band and added 10 ft. of steel to the band creating a uniform space between the band and the surface of the earth. What is the largest animal likely to fit under the elongated band: an ant, a mouse, a cat, a man?
OK Norm with band and 10 extra feet concentric to earth there is a 1.59 foot gap so the asnwer could be either the cat or a man assuming the man belly crawls thru the gap.
Dan Bentler
It's pretty obvious when you think about it?
Circumference = PI * D
So increasing D by 1 inch gives:
Circumference = PI* (D + 1) = PI*D + PI*1
Therefore increase in circumference = PI inches
The part that gets me is entuitively you would think there would be much greater difference in circumferance as you go out on wraps. But pi(D1- D2) holds true. Maybe the simpler things are harder to grasp or I just want to complicate it.
Dan Bentler
Logic would say that if the cat would fit, so will the mouse and the ant.
Dan Bentler
Then do it again with the circumference of the moon..
That is why the problem said "largest..." :p
Hi. I have to create an easy to use installation routine for my end-users. What I need is very simple. Copying some files and folders from an...
1,840
I've searched for this and I can't find anything on it. That leads me to believe that either the answer doesn't exist (highly unlikely) or it's...
1,958
Local Rockwell distributor was in today. He says that the MicroLogix 1400 will likely be unavailable to purchase sometime around the end of this...
58
16,763
Good Morning , I've taken on a job that is truly over my head with a engineering group. The standards of Rockwell programming is much more...
7,103
I’ve been looking at buying a quantity of signal converters to take a type J or k thermocouple or RTD and convert it to a 4-20mA signal. In...
3,024
