redlion controls
neekheeldesai
Dec 2003
qatar
dear friends,
hi ,I have redlion controls' paradigm SL-15 and SL - 40 display.
SL 15 is connected on quantum plc using proworx and SL 40 is new spare.
The connected one has stopped communicating to PLC ,not updating any Tag data,so I want to connect it with PC loaded with EDICT-97 S/W,and I want to download program to SL15 or SL40,So can anybody tell me the pin diagram for programming port RJ11(on SL15) to rs232(of PC) .Or can I connect PC on SL 15's RS232 PLC communication port.
Thanx.
Modicon port
I don't know anything about the Red Lion but, the pin out for the Quantum is:
Pin 1 - Shield
Pin 2 - RX
Pin 3 - TX
Pin 4 - DTR
Pin 5 - Ground
Pin 6 - DSR
Pin 7 - RTS
Pin 8 - CTS
Pin 9 - no connection
Note: Pin 7 should be jumpered to Pin 8 at the PLC.
dear Jim
thanks for the reply,I already have PC pinouts.what I need is cable pinout for Redlion SL 15 to pc connection.which is RJ11 - D9 female.
thanx
regards
nikhil :p
red lion controls
Dera Jim
Pl read PLC instead of PC in my previous reply.I have modicon plc pinouts,I need pinouts for a programming cable to program Red lion SL 15 module.and for that RJ11 to D9 rs 232 cable required.RJ11 will be connected to SL15 and D9 will go to laptop com 1 port.
regards
nikhil
When writing a User Defined action with Complex Code, can I call for a GoToPage "Popup"? I have a machine function that I want to confirm only...
48
Since the most recent Crimson update of C32-Gold-1016 I seem to have lost the ability to move files on the SD card. I run a background program...
54
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
161
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
200
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
252
