Redlion Memory Stick Transfer
ATU
Jul 2008
NC
276
I read several posts on Recipe storage on a CF card for the Redlion G3 Displays and noticed that the new Crimson 3 software appears to have some support for transferring files from the CF to a memory Stick ( I am assuming this is a USB stick?) I read the manual but its not clear to me how to initiate this. I want to be able to store recipe data in a csv file on the CF card and then transfer these files to a USB memory stick. Then edit the file in Excel and then transfer it back the other way and eventually down to the PLC. Is this possible?
Yes you are correct the units with a USB host port can support a USB memory stick. To configured the port you will need to go to the communications section of the software and click on Memory Stick. In the general tab you will set Enabled to Yes. In the transfer tab you will configure the direction of the transfer and what will be transferred. After that all you have to do is plug in the USB stick and the transfer is automatic.
Jeremy
The datastation does not have USB host ports. The USB host is something new that has been added with the release of the new HMI units.
Jeremy
Any plans to come out with a newer version that has them? I have applications where I need to provide this feature, but the equipment already has an HMI and the customer doesn't need another.
Try talking to your sales department, maybe a good sales person can talk your customer into accepting a CF card in place of the USB drive.
The USB would keep operators out of the electrical enclosure. They are a real stickler about arc flash regulations.
Does anyone know if you can get a Redlion G3 HMI to data-log that SB Memory Stick, rather than a CompactFlash card? We have a number of sites...
2,545
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
225
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
658
