Reg1 input
boudjul
Jul 2016
Ontario
Hi, at work we use kinetix 6000 with 2095 bmp5-s and I'm trying to use the Registration inputs 1 and 2, I have the hardware up to it on point with a nice 24v coming in but for some reason I wont see it being triggered in RSLogix. do I have to armed those input? how can I tell if my problem is hardware or software at this point? as far as logic goes I just jog the arm in one direction until my sensor picks it up
The tag for your axis will have status inputs:
Servo_Axis.Registration1InputStatus
Servo_Axis.Registration2InputStatus
These will show you if the drive is seeing the actual inputs(so use this to confirm the hardware works). You can use these tags in your program like a normal I/O input.
However, the real power of these registration inputs comes when you use them a high speed registration inputs. For that, you will need to Arm (MAR command) the registration input. After being armed, the drive will capture the exact servo position/time at the time the input is triggered/fired. For that you would then use the tags:
Servo_Axis.Registration1Position or
Servo_Axis.Registration1Time
Servo_Axis.Registration2Position or
Servo_Axis.Registration2Time
So even if it is not armed with a MAR command I should be able to see my input in the tags? I have servo_axis.Reg1InputStatus and .Reg2 in my tag list but they don't seem to change when I send 24v to trigger them. and yes my goal is to use the fast registration to stop the arm use its current position but right now I was wondering if my code was the problem or if the input wasn't functioning
I verified I had a nice signal to trigger reg1 and reg2 from an hardware standpoint, can the inputs be dead?, is there anything else I could do before trying switching to the backup drive?
Hello All, After trying to transfer some field changes on the safety scanner microscan3, and verifying, the device is stuck at .... waiting for...
61
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
89
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
266
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
93
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
95
