Remote access through CP343-1 Lean
orense
Apr 2006
Norway
196
Hello,
We are planning on installing remote access on a site. This is to connect to the Siemens PLC through VPN. At the present moment we are using a 315-2 DP with a 343-1 Lean card in the rack. By connecting my laptop to the Lean card, I am able to monitor the cpu.
We are considering changing the cpu to a 315-2 PN/DP, that is the cpu we are using on other sites with remote access.
Does anybody know if there are any significant differences with connecting through a Lean card, or connecting directly into a PN cpu ?
Since the plant is quite remote, I do not want to end up with some kind of compatibility problem because I assumed something...
Thanks for any info guys :)
Andreas
No, there is no big difference between a PN CPU and a CP343-1 LEAN card in this respect.
What is important is that the PN port or CP343-1 is setup with the IP address of he router that is used to connect to the LAN/WAN.
You can do your own test at home before shipping away to a remote location.
Hi all, Looking for a way to use my computer at home with Rockwell software and my internet connection to connect to a machine at my clients...
1,897
Hi, We have a plant running with 4 Siemens 315-2DP. At the moment I have set up a Westermo switch, in which we can connect through a VPN. In...
4,050
I'm looking for a solution to access wago 750-841 fieldbus controller over a GSM network. I was looking into ******* EW23205, but it is very...
3,625
I have a CompactLogix and a Paneview Plus standing in a remote area. Sometimes i want to check and change parameters on the Panelview from home...
4,315
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
620
