remote access
wancues
Nov 2012
moxee
49
so my it department has granted me access to are network form out side the plant. at this point i can see my drives but cant see or ping any of my plc's. so i an wording what i am missing or do i have to have a vpn router inside?
thanks any help will be great
This is highly dependent on what your network design.
If you can ping your PLC's from your desk, but not from off-site ..
- you may be getting access through a computer that is not routed to your PLCs. That would require some help from your IT department
Adding a VPN router would only help if your off-site access could see the VPN router.
i think the problem is that there server is not letting me see that part of the network.all of the plc's are on a different scheme ( computers 10.35.128.x / plc's 10.35.158.x ) i use the same laptop outside as inside.
I guess I was talking about the server that allows you access to the network, not the computer you are typing at.
For example, I get access to our network through a gateway that happens to be in our head office. That opens up a virtual machine or VM on a server at head office, which has it's separate subnets. Say 10.4.123.2 is the VM and 10.4.12x.xxx are the head office subnets. The IT guys then have allow traffic from that VM on that server to route to the site subnets, say 10.8.012.xxx then to our Bomgar gateway, in our DMZ, at say 10.8.015.xxx. The Bomgar then gives me access to ANOTHER VM, running in a server on our Control domain, at say 10.12.123.x ....
If I put a VPN router in my MCC room, at 10.12.123.xxx I still would have needed to get IT to route the packets from head office to site and through the DMZ and to the VPN router.
Or ... that's how I understand it ... which may or may not have any relation to reality. ;)
we use a system which allows us to log into our system.
its a fire wall, router, …
see if you can ping anything on the corporate side.
if so and you can't ping anything on the plant, they have a firewall block / router block in place. that's another issue to deal with.
I'm in the IT department with 2 others and we do all the plc programming …..
hope this helps,
james
What is the subnet 255.255.255.0 wont let those IP address communicate, 255.255.128.0 will let them communicate.
If you have a flat network, you can have multiple IP address on the single NIC. So, have 10.35.128.67 and 10.35.158.67 (I choose 67 at random).
thanks for the input guys. i have sent this info to IT and they are are looking at the best way to fix this. I will report on the end result
again thank you all
john
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
629
Hi everyone, I have a project involved with Toyota whereby the customer would like to be able to control devices within a booth using a portable...
245
Hello, I am looking for a solution to remotely access any kind of device securely across the internet. I know this has been done in piecemeal...
22
2,272
Hello everyone, nowadays i am working on a project for remote access to our machines. We are using a remote access module, but i want to make my...
404
Hello PLC Friends, I'm starting my final year project with a given rig and I'm thinking about incorporating a remote access feature where I can...
376
