Remote racks on Controllogix
Andrew_W
Oct 2009
Edmonton
38
Good Afternoon,
I'm helping to design a ControlLogix system in which we have 3 racks of I/O. Am I correct in my assumption that in each rack of I/O I will need a 1756-CN2 module to create my remote I/O via a controlnet network?
Thanks,
Andrew W
Good Afternoon,
Thanks,
Andrew W
Yes, but the CN2 may be overkill. You could use a 1756-CNB and save some $$$$
What type of cards are going in your remote racks?
Yes. Or use a 1756-CNB, which is cheaper but with slightly less performance and capacity. You'll also need one in the local rack with the processor
If you need a lot of io I would put it all on flex io or point io. It will save you panel space and you can field wire directly to the io card. Something like a 4 slot controllogix chassis to house the CPU and com cards, then your three racks of flex or point io. Probably a lot chcheaper to. But if you need high speed counter cards or motion control it may be a different story.
What is involved in Profinet comms to remote racks? Is it easier to use than Modbus comms? With Modbus I need to open and close comms for reads...
27
6,757
Hi im new to the emulator and im woundering how you test a program with a remote rack .have not been able to find any info in the manual about...
1,629
Hi, I design control systems where I use 24 VDC I/O. I always try to make my E-Stop circuit hard-wired (not relying on logic inside the PLC to...
9,821
I'm new to the GE Rx3i platform, up to this point most work has been Allen Bradley. I've got to add remote i/o racks to GE Rx3i controller rack...
4,511
I have a system that is controlled by 3 compact logix processors and i/o at each rack. This is a very large machine that has a lot of point i/o...
16,022
