replacing 5/04 CPU Ser. A with a Ser. B or C
Skidood
Oct 2016
Ontario
215
Hi again, my client may need a new CPU module and I want to sell them one anyway as a spare if needed. The existing CPU module is a Series A and I see online that I can buy new Series C modules.
In RsLogix, with the customer program open, in Controller Properties you can change the processor type from an A to C .... Just before you click OK, it gives you a warning popup stating "Changing the processor type may result in a loss of data and/or I/O configuration. Are you sure you want to continue?" I don't know how to interpret that message. Once you click YES, the program is somehow modified and checks out OK using File and Project checker. Is this a common and safe thing to do? Should I be concerned about doing this? When onsite I will be in an extremely remote location, I don't want to take any chances...thanks very much in advance .
Upgrading from a Ser A to Ser C is fine. The only issue would be the memory available.
If the Ser A is a -543 and the Ser C is a -541 then the program, if large enough, might be too big for the smaller CPU.
Thousands of CPU's have been replaced and I personally have never heard of the 'loss of data' RSLogix warns about. I think it is just a popup to make sure someone has to click a second confirmation. The only issue might be changing from a 5/04 or 5/05 to a 5/03 or 5/02 - some unsupported commands.
To be sure open a copy of the program and change the CPU, then do a Verify All. Save as Project_SerC.
Has anyone every had any loss of data or program from changing a CPU?
Module Configuration in GXworks3, I have a configuration with an R04 CPU and Slot 0 is empty Does anyone know how to replace the R04 CPU with an...
2,609
i would like to ask you, what are the steps in replacing a cpu? it is enough to insert the MMC into the new cpu or is it more to it?
2,015
We have a Fanuc RJ3 /iB controller. Suspect the CPU is bad. I have a backup of the System files , TP Programs , Application , Applic-TP , Error...
1,809
I have a plc @-20 in my factory where i cannot anymore upload the ladder program . . I Have in front of me a plc 2-30 .. Can i replace it ...
105
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
568
