Robot teach pendant cables.
Tharon
Jan 2007
Other
1,430
Quick question to those of you who deal with robots on a daily basis.
How do you handle the teach pendant cables? They always end up in a jumbled mess where I work. Apparently the operators and off shift maintenance like to preform some sort of elaborate mating dance with the robots while walking around the cage.
I always try to fold them in half twice, and hang them neatly over a wire hanger. But this never lasts.
The cables are roughly 20-30 feet long each, and I've been hesitant about using things like cable reels because I don't like the idea of pulling the cables up.
I think I would coil them neatly and put in a large box. This will keep them clean and undamaged. If you dont want non quals fiddling with them then lock the box.
Dan Bentler
We made a hook for the pendant and cable. Production have no reason to use the pendant in our application and maintenance seldom unravel more than one wrap of cable. Once in awhile we will untwist the cable, but this is very seldom.
We try to eliminate production's need to use the pendant, but unfortunately with our setups there is always the small chance that a crash will occur. And with 1000s of cycles every day, even a small chance makes the number of occurrences more than just a few. Then they have to use the pendant to move the robot clear of the crashed position. Meaning they will have to carry the pendant to the robot location to watch and carefully move the robot free.
It's just that some people must not know how to walk in straight lines, and twirl around a few times while walking with the pendant.
We had cable failures because they were removed every night during sanitation so the connectors would corrode. I bought some stainless steel enclosures and put the hook and pendant inside so we simply close the door at night to keep them dry and leave them connected. I had to search here for the cable gland big enough to seal around the Fanuc connector but it put and end to our failures, and the cable usually stays nicely on the hook unless we have to drag it out for troubleshooting.
ABB has a HotSwap option, whereby you can remove the pendant, by use of a momentary pushbutton that jumpers the estop while you remove the pendant, and a jumper plug that passes through the estop signals (which is installed while you are holding the button, but keeps things right after you release it.)
Good Evening , We have a Fanuc LR Mate . Our operators have the habit of grabbing hold of the robot to clear a crash , or find the witness...
4,090
Hi, folks, how are you? Is there some way to lock/freeze Fanuc robot teach pendent? Since some of our operators jumped program lines with teach...
1,734
Hi, i have a fanuc robot with a R-30ia mate Open air controller, and a broken teach pendent (TP). is it possible to disconnect the TP and make a...
2,584
I have a project with a large array of servo drives, as part of the setting up sequence i want to follow the way robot's work during teach mode -...
4,796
hello, I'm a student and for my final grade I have to repare a sepro robot. the only problem I have for now is that i have an error code 3...
51
