ROC 800 firmware mismatch question...
timothy585
Supporting Member
Apr 2021
Cajun Country
47
I'm on a job with about 75 ROC 800 LACT packages installed and running. We have a single template program that works good and is basically just dropped in each unit lately with minor changes to network addressing for the ROC and OIT, etc.
Anyway, I've been using ROCLINK(2.61) for the development the past six months or so and everything has been going smoothly. Today, we received a new LACT unit and when I went to download the current program I received the pop-up regarding firmware mismatch.
WARNING:
Connected device Firmware Version is 1.64,
Configuration File device Firmware is 1.62.
I downloaded the program thinking such a minor firmware change would not affect anything, but I immediately got an error to the effect of a compile error and it will not run. I can open IO monitor and see a physical DI point change state, but nothing is happening in any of the action blocks, etc.
What are my options?
Can I re-compile my current 1.62 program for 1.64 firmware?
If so, will it be backwards compatible with 1.62?
Can I downgrade to 1.62 firmware in the new hardware and keep my current program?
Or is it possibly something else, and this minor firmware revision should not be affecting it?
Thanks.
A new LACT skid was delivered seemingly identical to the other 20 before. We have a config file that we have been able to download without issues...
736
Anyone happen to be familiar with ROC 800 flow computer hardware? I'm new to the ROCLINK 800 programming software and I have a quick question...
838
Hello, I am needing help with the configuration of a ROC 800 RTU, I have not been able to configure the softpoints with measurement instruments...
827
Hi guys, I'm trying to configure a rate of change alarm on a setpoint tag so that when the operator types a number by error (exemple: 30 instead...
204
Today I was making an online edit to a 5/40 Series E Rev K.2 with about 14% free memory. I was removing one branch in a large rung. Accept...
3,195
