Rotary Encoder
OT: pedagogy and philosophy
I don't think of it as multiplying by unity but keeping the units straight ...
So do I, but then you and I just know this stuff.
"Keeping the units straight" is an abstract concept that presupposes the underlying knowledge, so it is less useful pedagogically; "multiplying by unity," on the other hand, contains the same concept but expressed in a way that connects directly to the knowledge to be gained, i.e. that unit conversion does not change the quantity in question. So in my experience it has a better record of converting outsiders into cognoscenti.
But yes, I agree that, in the end, multiplying by unity, keeping the units straight, bookkeeping, potayto, potahto, are all the same.
@kalabdel
Yes, it is doable with two induction motors, running both conveyor and knife. You have to have premium quality VFDs and good encoders . Also if required speeds are to fast or there is high inertia, then servos are solution.
Years ago I had Emerson demo their unidrive M700 series and they were amazingly precise and were not all that expensive, for smaller motors. It would be fun to try, just have to find an oldie machine to play with.
sounds like you broke the OP?
but converting units of circumference for whatever wheel is attached to the encoder, and scaling it to inches/mm for the operator to enter shouldn't be that monumental of a task.
If the issue is figuring out how to make an encoder work, then the next step of spending money on a servo, controller, ball screw, thk rails, etc to make an accurate flying cutoff die assembly.... may prove to be what puts a cork in this project.
Our store has few DIGITAL DEVICES Rotary Encoder which is original used on obsoleted USA weighing scale for speed feedback. But we has no idea how...
2,211
so im trying to figure out a little setup in my head for a machine and im looking for some advice. im using a micrologix 1400 so i figured i could...
4,452
Hello, all. We have one 840Dsl milling machine and a (absolute rotary angle) encoder alarms show up. We took it out for checking, then put...
1,472
Hi, Everyone I am interfacing rotary encoder(incremental encoder) with PLC. This encoder using for speed measurement (RPM). The encoder is giving...
4,538
I am needing a rotary encoder switch. Preferably, it would have screw terminals for connections. I'm looking for it to have a digital pulse as...
3,393
