Rs 232c
techimnot
Jan 2008
TN
17
I am trying to communicate with an Emerson FX 455 positioning drive using the .pcx software. I have done this in the past, but am now having trouble communicating. Have tried different baud rates as well as different RS 232 cables. I am wondering if there may be a different pinout in a 232c, or in the 232c does the "c" mean "current" as I have read. I am thinking one of my co-workers has the cable I used locked in their tool box.
I'm not positive on the exact specifics of why, but IIRC a standard RS232 cable doesn't work with the Emerson drives.
The cable we use for PCX has 2->3,3->2, and 5->5 wiring. All other pins are open (not tied through or looped back). I believe that's the trick to getting comms.
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
598
Hi, is that anyone know the pin layout for the communication cable from Mitsubishi Q00UJCPU (6 pin mini) to any Schneider HMIGXU (D sub 9)...
1,122
I'm looking to extract the Weight from an Ishida DACS-G back to a Compact Logix PLC. I'm currently looking at two options, the 1769-ASCII module...
1,837
Hello guys, Can any one please share the communication diagram of Micro logix 1400 channel 2 RS 232C pin wiring configuration...
6,718
Dear All Can anyone help to communicate ascii rs232 to s7 300 PLC through Cp340Rs232. RS232 9600 baud, 8 data bits, 1 stop bit, no parity, no...
1,359
