rs 485
prakashn
Jan 2004
how to connct from an rs 232 to rs 485 converter to a ge fanuc 90- 70 plc having 25 pin connector. convertor is having only data plus & data minus signals.
n,prakash.
Go to gefanuc website infolink and look on the manual of the CPU, you should find the right wiring with the correspondance on each data transmitting pins.
Eric
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
261
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
155
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
164
Hello, I'm trying to delve a little into rs-485 communications for a couple projects of mine. Until now I've been using a delta vfd and a delta...
131
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
212
