Rslogix 5000 data logging/
stu
Aug 2005
England
783
Hi Guys
i have a machine which i would like to record the down time, the machine has a rsview 32 hmi and we have a compact logix plc, i have not done any data logging before but i would like to learn.
what i would like to do is for every time the machine stops i would like to record the downtime and total downtime for the day up a weeks worth?? (on the hmi)
has any one done this before
It's going to be pretty easy to get an accurate total with some PLC code.
Just use an RTO timer that runs only when the machine is stopped. Show its .acc on the HMI. Reset it daily based on clock time.
If you want to record each occurrence of downtime and log them separately, then I would have to defer to others on how to do this with View32
i have been told to use a fifo instruction but i am not sure how to use it??
what am i looking at on a fifo
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
518
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
133
I have a micrologix 1100 that I am trying to read three data points from it on my safety plc using studio 5000. Any tips or guidance is appreciated.
848
I want transfer my I/O data from schneider (Unity Pro) as a write data and RS Logix 5000 as a read data. I use Ethernet as an communication...
696
Im trying to sum a running "Shift Total" production value and move it into a Month Total value that will continuously update for viewing...
1,536
