Rslogix 5000 error
Airborne87
Jan 2007
mn
Anyone ever seen this error in logix 5000? Failed to go online with the controller. Invalid communications path or controller not responding. In the left hand side of the box I have the error 701-0004200c. I spoke to tec support and was told I can not find anything on that error. My other laptop is almost identical and i have no issues to the same processor. With the new laptop I can see everything in linx but I recieve this error in 5000.
While I don't know that error code, that message means the path in the online toolbar is not correct for your controller.
Try going online without using any shortcuts.
Select Communications from the menu bar
Select Who Active
Expand the proper network driver until you find your controller
Select the controller
Click Online
OG
Hi All, I've been pulling my hair out trying to fix this for a few days and need some advice. I have V19.01, v20.05, V21, V24, V30, V31, V32...
441
Hi, I am trying to upload program from Contrologix 1756-L62 Controller using Rslogix 5000, Cpu's and modules are showing in Rslinx, upon...
962
I've googled and searched for this error but can't see it anywhere. When I try to open this program I get the following. Error 0x8004201d...
4,033
Hi all, I installed a RSLogix 5000 V20.04 to my Windows 10 system today, and it seemed everything is ok before I started it. The software gave me...
2,964
fatal error in rslogix 5000 v20 Error 0x80042082 RxE_locale_changed_by_outside- the locale language Settings for RSLogix 5000 was changed
2,024
