RSLogix 5000 Flex I/O Calibration Tab
Rupert
Jul 2007
Perth
I would like to calibrate a flex I/O module but my installed version of RSLogix 5000 does not have the calibration tab under the I/O configuration windows.
Does anyone know how this feature is turned on and off.
Is it an installed software component, an add-on or something else.
Thanks for any advise.
Rupert
Rupert,
I am not a RsLogix 5000 user, but I do know that those that are
and can help you will need more info.
What version of RsLogix 5000 do you have?
Which processor are you using, complete cat. no. series firmware?
Which Flex I/O module do you have , complete cat.no series?
How are you communicating with the flex I/O, Controlnet,ethernet,remote I/O?
FYI,not all Flex I/O modules can be calibrated.
Rslogix 5000 Ver13.03 with a 1756-L63 ControlLogix 5563 Controller.
The module I'd like to calibrate is a 1794-IRT8 8 Ch 24V DC RTD/Thermocouple Analog input unit.
I'm using controlnet to talk to the processor and flex I/O
Rupert
I would call tech support to see if there is a rev level of that module that can do this. I would think no. Flex is very simple and does not have the features of ControlLogix modules. There is a reason why they do not cost very much.
Rupert
Here is a screen shot of V16 using C-Net to interface to the flex.
There is no calibration available
Ian
The rev of the card dictates what features are available in RSLogix 5000.
So you can have your processor up to Version 16 but not gain a thing on the amount of data that comes in. This is done by having a higher reve card AND adjusting the rev of the card in the I/O configuration. Please note that you need to also adjust the card rev in the I/O configuration which will add all the tag data for the features at the rev level (if any). But you can only do this when the physical card is atleast as high as the rev you select in the I/O configuration.
I cannot tell you what all you get from higher rev as it changes from card to card.
This being said, I am pretty sure the Flex modules have not seen to many rev increases over the years. They have been around for a long time. I added a 1794-IF4I last year. If my memory is correct, it was still sitting at a really low rev. Heck, you still needed to scale the inputs (no scaling in the card).
hello i am trying to set the max frequency for the drive via rslogix 5000, but do not see that patameter in the rslogix 5000 drive paramerts? the...
323
Anybody can help me. I already read document in software rslogix 5000 and I think i can use software rslogix 5000 calibrate for flex module...
1,744
I have an older system and they recently replaced the VFD to a newer revision. I tried to modify the VFD in the program to the new revision but...
4,729
Hello, Currently on my laptop have rslogix 5000 v16_20 and I'm not able to see the compare sheet of parameter for vfd powerflex 40p over comm e...
1,293
Hello All, I have been trying to add powerflex 755 rev 10.02 to rslogix 5000 rev 20.1 and its not showing. I can see the drive in rslinx with a...
5,684
