rslogix 5000 standard bit to safety bit
gerberz
Jan 2017
Midwest USA
26
I have found a array of bits in a plc program. That are turning "To_Safety[0].0" (standard bit) to "From_Stand[0].0" (Safety bit). Neither is a alias also when i cross reference "To_Safety[0].0" or "From_Stand[0].0" all i get is "To_Safety[0].0"=OTE and "From_Stand[0].0"=XIC. When i cross reference "To_Safety" or "From_Stand" all i get are "To_Safety" = OTE's and "From_Stand" = XIC's/XIO's.
Can someone tell me how you can turn a standard bit to a safety bit?
Also how you can change the name of the bits like that?
You will need to map safety tags. From the top menu select Logic then click on Map safety tags. This will open the Map safety tags window.From here you can map safety tags to standard tags.
I feel obligated to point out that while mapping a bit it can be used in a safety program it does not make it a 'safety' bit. Every precaution still needs to taken that using that bit doesn't lower the safety integrity of the function where it is used.
Thanks so much! I just came across this issue and I looked into all kind of direction. I was assuming this kind of info should be displayed either in properties (right click) for example like the consumed tag is or the most detailed properties tab on the side.
How can I add the "Go To..." function to the RSLogix 5000's Standard Toolbar?
3,598
Does anyone know the Current Price for this software? I have contacted my AB Rep. but he has failed to get back with me. Also I plan on using it...
8,222
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
158
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
586
