[RsLogix5k] Convert csv to plc table
iglesdavid
Aug 2017
Colorado
Hello all,
I have a csv file produced from rslogix that periodically logs the current state of analog inputs and alarm bool conditions and stores it in an SD card on the controller (1769-L33ERMS).
How could I generate a table in the PLC if I wanted to import these logs?
Example of the output:
>"42949,0.78708851,1.10000002,2.22000003,3.33299994,4.44439983,5.55555010,6.66666603,7.77777767,8.88888931,10.0000000,0.0"
Now as an supervisor, I want to use a mobileview tablet to ask the plc to pull up the logs associated with the first column (which is the date in DINT format) and review the entirety of the day on the HMI.
What comes to mind:
* Do I need to go and make a string parser that stores the information between delimiters (,) and STOD/STOR as needed?
* Can I store those values in a way that I can then format to view on the mobileview? A table would be extremely nice
* Is this an over-engineered approach to a very simple solution I'm not seeing?
Thanks,
David
Hello PLCs.Net! I am trying to use RSLogix5k via windows command line. I would like there to be a script which automatically opens a project...
1,249
Hi, I recently installed a powerflex 700 drive in rslogix5k i/o tree. I am communicating thru a 20commE. I have no communication issues or faults...
1,597
I've heard someone saying I should put as many programs/routines in the continuous task. I also heard others saying use as little continuous task...
18
6,466
Gents, I've a CompactLogix L35E V19 and a Telemecanique XUW vision sensor. There is an EDS file from the XUW, and I used the EDS hardware wizard...
1,579
Has any of you guys have experience problems with RSLogix5000 and AutoCAD electrical 2015 when they co-exist on a windows 7 Enterprise computer...
1,068
